We have had this integrated fridge freezer since 2008. It seems to be running the compressor for an hour and 15 minutes and off time of approximately 45 minutes. I decided to monitor the energy use and it’s currently using a little over 1 kWh a day which I think is over what it should be.
The fridge freezer only has one rotary thermostat controller in the fridge section but may I ask if the freezer temperature is regulated by the on/off cycling due to the fridge setting or will it run independently to attain – 18°C in the freezer?
The fridge back is auto defrost but the freezer needs a manual defrost which I have just done this morning.
