Neff K9625X0GB FD8012 Fridge temperature
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Neff K9625X0GB FD8012 Fridge temperature
  • #27736
    BenPope
    The temperature in the fridge is too warm, the freezer seems ok, there is not excessive ice build up or funny noises, the door seems to seal.
    What do you think is the problem?
    #215394
    gegsy
    Re: Neff K9625X0GB FD8012 Fridge temperature
    I think you have a system fault ie compresser or refrigerant problem.
    This is not a DIY repair and will need pro attention.
    Please feel free to locate a local engineer in your area from the link below.
    BenPope
    What makes you think it won’t be the thermostat? (not flame bait, just interested in the diagnostic procedure)
    #215396
    gegsy
    There is only one compresser and thermostat on this appliance therefore only one refrigerent system.
    The thermostat is in the fridge which activates the compresser then feeds refrigerent to the freezer first, then as the refrigerent makes its way around the system back to the compresser it still has enough chill to cool the the fridge, if any of what I mentioned in the first post are apparent then you will get your fault.
    I take it the compresser/motor can be heard more or less continuously until maybe its protection kicks in and stops it for a short period?
    BenPope
    Thanks for the reply. I have not inspected the appliance myself, I asked if the compressor was running continously and the answer was unknown as it is quite quiet.
    I will have to check myself, I suppose.
    Again, thanks.
