Neff lower oven not working.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff lower oven not working.
  • #72198
    kamaca
    Neff oven. Model No. U1421NOGB/06.
    Lower oven not warming up. The fan and temperature-control light are functioning OK.
    I ordered a new element from Whitegoods, but still had the same problem after fitting it.
    The old element tested open-circuit and had obviously failed even though there were no visible signs on the outside.
    The new element checked out OK, (clutching at straws I know, but it’s not impossible for new components to be duff), so I checked the element supply cables and there is no power coming through.
    I have read a similar case here where the poster was advised to check the limiter, and I’m hoping that someone can tell me if this is the most likely next step.
    If so, I suspect this is going to be an “oven-out” job (groan) and would be most grateful if someone could tell me where to find this component once the casing is off.
    Many thanks.
    #383819
    stevebunyan
    Re: Neff lower oven not working.
    Does the clock need setting on that model?
    Failing that check the thermal cutout and commutator(selector switch)
    This is a oven out job and as always turn the power off.
    Regards
    Steves
    #383820
    kamaca
    Thanks for your help Steve.
    Yes the clock does have to be set on this model. If only that was the problem.
    I’ll try replacing the cut-out first. Do you have any idea where that might be located?
    #383821
    stevebunyan
    Usually on the back
    #383822
    kamaca
    Fitted the thermal cutout and it’s now all up and running.
    Thanks for all your help.
