neff m/w
  • #69801
    clockworkone
    neff h5642s0gb/05 s/n 7290138. I dont normally touch microwaves but have reg cust with one of these built in jobs in which the turntable has stopped.everything else works ok.Is it a straightforward enough job just to replace motor(602110)Paul
    #376049
    Re: neff m/w
    easy, assume you can get the thing out of the housing (check length of main lead). there is a removable round panel under the motor, just snip the thin metal bits off with a pair of old cutters and remove the panel. 2 screws, 2 wires and bobs you old auntis son. Just re fit the panel with a couple of small self tappers. If you have assistance, you may be able to do this just by pulling the microwave forward just enough to access it.unplug it though as that motor is live even when off!
    #376050
    clockworkone
    Re: neff m/w
    thanks eastlmark, that was the kind of answer i was hoping for.paul
