neff micro H7871
  • #22015
    jimjam
    hi everyone, I have got a neff microwave Eno.H7871NoGB and FDNo 8110582250 still going great, but now as the oven heats up it affects the door switch and thus malfunctions. By that I mean the lluminated icons that should stay lit all the time whilst cooking start blinking as if the oven door has been opened and thus have to keep putting light thum pressure on the door to keep it going (not conveneint) require new part type door switch.. also the rotating wheel at the top of the oven under the glass cover now squeaks alot mainly when the ovens hot.. sounds like bearing running dry or something similar metal rubbing against porcelain etc… Any help greatly appreciated Thankyou in advance!
    #193432
    gegsy
    Re: neff micro H7871
    Hi jimjam
    Im sorry but we are unable to supply parts or advise on any repair which invloves working on it internally due to the high voltages stored within. 🙂
    jimjam
    thanks gegsy….Sorry I should of mentioned Im an NIC registered electrician and used to working on such high voltages. Alot of my work involves installing very large 3ph machinery, Heidelberg 7 colour printing presses to name but a few. Recently we had to run a 150mm 4core swa round the outside of a building on cable tray 10′ up. It was delivered on a 6′ diameter drum which had to be hydraulically lifted of the ground to enable the drum to rotate.. and because of the sheer weight of the cable had to be manned every 15′ so as it could be pulled of the drum….I could bore you with the combined loading current of the press and its dryers and calculated volt drop over the lenght of run …but at the end of the day all i wanna do is fix my micro 🙂
    #193434
    gegsy
    Hi jimjam
    It wasn’t a dig at you or your ability, its just that this being a public forum, it will be viewed a number of times and their ability may not be the same as you or I, you see?
    If you need trade access so we can advise further please contact admin@ukwhitegoods.com to facilitate that.
    Thanks for your understanding
    jimjam
    No probs gegsy. I totally understand, I will contact them asap.
    Thanks again! 🙂
