neff micro wave – turntable turning when not in use ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries neff micro wave – turntable turning when not in use ?
  • #80525
    funkyboogy
    h5642sogb/04
    unit works ok as a micro wave but when its not in use the turntable turns and the light stays on ..
    any help appreciated
    cheers ally
    #413204
    SWERV
    Re: neff micro wave – turntable turning when not in use ?
    I have had a short in the turntable motor that has caused that fault. I couldn’t believe it myself, but nothing suprises me these days. Also worth checking door switches, failing that, it will be a board fault.
    Sent from my iPhone using Tapatalk
    #413205
    nomadPaul
    Door switches is a good shout .
    #413206
    A1TEC
    nomadPaul wrote:Door switches is a good shout .
    I would have thought the monitor fuse would be taken out if the door micro switch assembly was faulty but you never know. 😕
    #413207
    funkyboogy
    cheers guys will check – door switch,s a bitch to get at – im thinking the same that monitor switch would have taken out fuse .
    will check turntable .. unit is 10 year old but cust wants to keep
    ally
    #413208
    funkyboogy
    UPDATE , swerv was correct – turntable motor faulty sp weird as it works ok when microwave on ..any way cheers guys
    me happy customer happier
    ally
    #413209
    SWERV
    Nice one.
