neff microwave
  • #49179
    PlanB
    Hi does anyone have any tech info on Neff 7871n0bg03 combi oven. Customer brought one in claiming F4 on screen after power cut. Unit powers up display flashes with the usual zeros, then fades away and unit is inoperable. Not sure which board to suspect. Any help greatfully received
    kindrst regards
    patrick
    #298988
    superfix
    Re: neff microwave
    most likely will need all three 🙁
    check the main relay board tracks. The lamp can blow the puds out of it also the steam flap actuator can do the same. Problem is it can flash over to the display boards too.
    If this is the case it will be VERY expensive.
