Re: neff not cleaning
If you have checked, especially the ribbed pipe at the front from metering unit to sump, and there is water just below the bottom spray arm mount, then I would be looking at the recirculation motor; either weak,start capacitor or possibly the impeller may have become detached.
If that is the case you will need p/no 165813 available from spares@ukwhitegoods.co.uk 😀
Unplug appliance before investigating further :plug:
Regards
