Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › NEFF oven
- This topic has 12 replies, 2 voices, and was last updated 6 years, 8 months ago by
JSTANLEY.
August 5, 2019 at 12:49 pm #96226
JSTANLEY
ParticipantHi, just moved into a new house and having problems with a NEFF oven.
it has alot of different functions which most work. But the main fan doesn’t work and neither does one of the bulbs in the oven. The other bulb works with grill etc but the other side connected with using fan oven option doesn’t.Can anyone help me out with what to check please?
Its a NEFF E-Nr B1641N1GB/09
FD8209August 5, 2019 at 4:58 pm #462729electrofix
Moderatorif the unit has a clock has it been set to manual
just so you know this unit was built sept 2002
August 5, 2019 at 7:39 pm #462730JSTANLEY
ParticipantThank alot for the reply. Only just moved into a house with this oven in.
ive set the clock to the correct time if thats what you mean?August 5, 2019 at 8:11 pm #462731electrofix
Moderatorsince the clock controls the oven if the clock is not set to manual then the oven wont work
if its not that then cant think of anything else simple and the control part look expensive
August 5, 2019 at 8:29 pm #462732JSTANLEY
ParticipantDo you know where i could get a wiring diagram for it?
August 5, 2019 at 9:18 pm #462733electrofix
Moderatorpart diagrams yes no prob
wiring info is hard to find. only available to designated agents and I am not one so have to use experience and educated guesses
August 6, 2019 at 12:17 pm #462734JSTANLEY
ParticipantAh ok thanks.
Once i strip the casings off whats the best way to test the fan?
got a feeling it may be the main board/pcb so will remove that and see if theres anything abviousAugust 6, 2019 at 6:54 pm #462735electrofix
Moderatorwell if it was the fan the element would still get hot
most time fan fails mechanically so see if it spins easily
you can check both with a multimeter
DaveAugust 6, 2019 at 8:39 pm #462736JSTANLEY
ParticipantThe element does get hot and the fan spins easily
August 6, 2019 at 9:43 pm #462737electrofix
Moderatorcould just be a faulty motor then
worth checking
August 6, 2019 at 10:22 pm #462738JSTANLEY
ParticipantWhat ohm setting do i use on a multimeter? And what should i expect to see if its good or bad?
August 7, 2019 at 12:07 am #462739electrofix
Moderatorif its open circuit you will see readings of thousands of ohms
if you get a reading under 1000 then there is a circuit there
DaveSeptember 8, 2019 at 10:41 am #462740JSTANLEY
ParticipantOnly just had time to have another look.
the fan hasn’t got any power going to it.
Anyone know what to check? Took the pcb out to see if any burnt tracks but none found. Anyone know how to check if it is the pcb? -
