Neff oven
  • #103078
    suedehead1
    I am trying to change a fan on a neff oven, its a large aluminium fa I have got the nut off but cannot
    remove the fan its absolutely solid tried 2 screwdrivers in the back of it, put the nut back on and hit it with a nammer
    but it will not move.its the motor with 4 legs which just pushes on and turns U14M42N5GB/01.
    I am sure someone has had this problem before any ideas?
    #491719
    put spanners at the back and jam them in. Then use heat with a heat gun or blow lamp
    then hit it with the nut on. bit of wd can help but oven will smell for a bit when used next time
    suedehead1
    ok i will give it a try thanks
