MODEL B1593NOGB/07
WHEN TURNING ROTARY KNOB TO SELECT TEMP THE DISPLAY JUMPS. FOR EXAMPLE TURN LEFT TO COOLER AND IT WILL JUMP UP TO HIGHER TEMP. SPOKE TO NEFF RECOMMENDED LITTLE DISC TO FIT. TRIED IT NO JOY. ANY IDEAS OTHER THAN THE COSTLY CONTROL MODULES?
THANKS
THANKS A LOT FOR YOUR HELP
SHOULD THAT CURE IT AS IVE NOTICED ANOTHER MODULE (CONTROL UNIT PART 264982) AND CUSTOMER DOESNT WANT REPAIR IF BOTH PARTS ARE NEEDED.
THANKS AGAIN
Can’t see that module anywhere on it 😕
The module 264472 comes as 2 parts connected by ribbon cable.
The main part of it accepts the knob and engages the rotary selector unit on PCB (the knackered bit) 😉
