Whilst using the oven a while ago the main fuse in the house triggered, when I re-set the electric the oven would not work ( the time display works and I can hear and feel the fan working). Is this just down to the fan element. The oven has two elements (the fan element) and an element in the roof of the oven used for grilling, that element doesn’t work either, I doubt very much that both elements would fail at the same time – any thoughts appreciated thanks
Yes…very unlikely both elements would fail together considering they are never both in use at the same time! Certainly sounds like classic fan element failure, is it possible the other element failed some time ago?
Of course the only definitive way to check an element is to use a multimeter, look for about 20-30 ohms. Often you can see visually if an element has popped….
