Neff oven B1442N0GB/10 Tripping RCD
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff oven B1442N0GB/10 Tripping RCD
  • #87646
    Kidjam
    Need some help please. The oven is tripping the rcd when not powered on. When cooker is switched on from the mains isolation switch the timer comes on and displays for about 15-20 secs before tripping the rcd. Could this be a problem caused by a faulty clock unit? Any help appreciated , thankyou.
    #435504
    Re: Neff oven B1442N0GB/10 Tripping RCD
    Very unlikely to be the clock and more likely a duff element.
    #435505
    Kidjam
    It trips the rcd when no function is selection, therefore no heater circuit is energised. Any other ideas what the fault could be?
    #435506
    Kidjam wrote:therefore no heater circuit is energised.
    The elements are not fully isolated though.
    Kidjam wrote:Any other ideas what the fault could be?
    I’ll stick with a faulty element, but the mains terminal block, the oven lamp, cooling fan, thermostat and selector switch can all be suspect.
    #435507
    SAMURI
    The oven switch may be faulty but it is hard to tell without testing.
    Bob
