NEFF oven B47CR32N0/01
  • #103627
    dunston
    This oven is over heating. It continues to heat but doesn’t cut out. The customer said it happened after it had been cleaned. Any common faults?.
    #494009
    its full electronic so its either
    a coincidence and the fault would happen anyway
    or water has got somewhere
    you say it never cuts out but I expect some sort of limit
    suggest you take thermometer with you set it on very low temp and see
