Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff oven B5ACH7AHOB/72 operating module, variant code
- This topic has 7 replies, 4 voices, and was last updated 4 months, 3 weeks ago by
snig.
November 13, 2025 at 6:12 pm #103661
snig
ParticipantCustomer has erratic temp display, tried new probe ( which customer had purchased ) but still faulty. Ordered display module which came with a note saying to set variant code/ touch calibration but no instructions on how ???
November 14, 2025 at 11:51 am #494115Steven
ParticipantDoes the temperature still work correctly when set although being erratic does it over heat? Before fitting display, I take it elements checked for low insulation especially the base one can cause weird faults on the electronic stuff. Could be ribbon connections from main board?
Neff wont supply any tech! :rolleyes:
November 14, 2025 at 3:04 pm #494116snig
ParticipantDoesnt overheat. After a couple of minutes temp. will alter itself, normally down.
Pretty sure i would of checked elements but can’t actually remember. I may go back and check again when hot !!November 14, 2025 at 6:29 pm #494117Hollytree_Technical
ParticipantDoes the temperature revert back to the default start temperature for the cooking mode? If so then I would suspect that it is the program selection switch is very slightly grotty causing it to think that you changed the mode and then put it back again before the display catches up.
Jem
November 14, 2025 at 9:51 pm #494118kaibart
ModeratorJem is spot on it the selector switch done loads of them variant coding is easy on the date plate on the back it has v.c what ever number that is you scroll to it and switch the oven off at the on /off switch on the switch on the panel for touch calibration you need the test programme and a test finger
November 15, 2025 at 8:54 am #494119snig
ParticipantYes, thats exactly it. Reverts to default. I will try a new selector switch.
How do you access the test programme, does it come up after switching off then on ?? and whats a test finger ??November 15, 2025 at 10:03 pm #494120Hollytree_Technical
ParticipantI don’t know the procedure as I have never done one but I think that 15000283 is the test finger.
Jem
November 16, 2025 at 6:10 pm #494121kaibart
ModeratorIf you change the selector switch you won’t need to calibrate the touch controls, the test programme is only for bosch engineers and you use the finger to calibrate the touch controls
