Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff Oven – Bulb Repeatedly Blowing
- This topic has 9 replies, 3 voices, and was last updated 11 years, 9 months ago by
whoami.
June 23, 2014 at 2:58 pm #81183
whoami
ParticipantHi,
the first bulb in my Neff oven lasted c4 years. However, three replacements (so far) have last a few days each.
Before I arrange an engineer’s visit, is there anything obvious that could be wrong with the oven?
Thanks 🙂
June 23, 2014 at 3:41 pm #415713Martin
ParticipantRe: Neff Oven – Bulb Repeatedly Blowing
Are you fitting the correct replacement oven bulb?
June 23, 2014 at 4:12 pm #415714whoami
Yes, correct wattage and temperature rating.
June 24, 2014 at 8:41 pm #415715whoami
Any other suggestions?
June 24, 2014 at 8:48 pm #415716SAMURI
Keep finger prints off the bulb as this can cause heat spots on the bulb.
If you have to use your fingers on the bulb wipe it with a soft cloth before putting the cover on.
Bob
June 26, 2014 at 11:22 am #415717whoami
Thanks – made sure that I did that too.
No fingerprints on the bulbs when changing.
Oh well, one more try then a call to Neff.
June 26, 2014 at 12:01 pm #415718Martin
whoami wrote:Oh well, one more try then a call to Neff.
What is the model number of your oven by the way? Some makers of oven bulbs (e.g. Ring) are best avoided. Likewise Pygmy lamps are more reliable than globe types I find. Wattage also can be an issue and fitting a lower wattage, less bright I know, but can often last longer.
June 26, 2014 at 12:18 pm #415719whoami
It’s a Neff U16E74N3GB.
I did wonder about the bulbs. Have bought a different brand from a local “old school” electrical shop as a last attempt.
Could there be something wrong with the oven causing the bulbs to fail or do you just think it’s a bulb issue?
June 26, 2014 at 12:45 pm #415720Martin
whoami wrote:Could there be something wrong with the oven causing the bulbs to fail or do you just think it’s a bulb issue?
Bulb housings can be an issue but as a rule the electrical contacts within them fuse together and blow the RCD. If a bulb works when screwed in then goes out later then it’s a failure of the bulb as a rule. Those 40watt globe bulbs are a pain and it may be worth just trying a 25 watt Pygmy bulb instead. As I say it gives less light but provided the lens is kept clean it’s bright enough. Worth a try at least. 💡
June 26, 2014 at 12:56 pm #415721whoami
Thanks Martin, much appreciated.
