Neff Oven bulb replacement
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Oven bulb replacement
  • #81762
    Rampaudio
    Hi there, I want to replace the oven bulb in a Neff 195 305 766.
    I was expecting to see just a glass lense to twist off and reveal the bulb but found a more rectangular shaped lense, that I think is made of plastic. Neff say that there should be a clip holding the unit in place but I have got right up close to it, ran my fingers around the whole lense and taken a picture too and I can’t see any clip. If it’s a case of running a screwdriver around the edge of the lense so it pops off, I’m a bit loathe to do that, as the oven I guess is well over 20 years old and knowing my luck the plastic will be brittle and possibly break. Any ideas? I’m happy to take the entire oven inside shell out to avoid breaking the lense but that’s a lot of work! Or should I “man-up” so to speak and pop that lense with a flat screwdriver to reveal the bulb?
    *** The more crud that comes off this lense I can now see the lense is glass.
    #417625
    philfish
    Re: Neff Oven bulb replacement
    I certainly would not recommend taking the inside cavity out that’s for sure!!!
    Have you checked to see if you can get a replacement lens?
    Do you really need a light that much? Only say that because if you can’t replace the lens and it does brake your in deep do do.
    Phil
    #417626
    That is one yucky oven you have there but that glass lens is just a push fit into the housing. Just a gentle lever on one side and it should come clear.
    #417627
    Rampaudio
    Cheers for your replies. Popped off as you mentioned Martin thanks mate. …….Dirty keyboard too…. Full of tobacco…
