Neff oven cooling fan
Home Forums General Trade Forum Neff oven cooling fan
  • #102917
    grazzamongrel
    Hey dudes, I went to a Neff built under oven model JIHCC0AN0B/01 and the cooling fan never turns off. So I turn on grill briefly and cooling fan turns on and when I turn grill off cooling fan also goes off. BUT when I leave main oven on for a while and cooling fan is activated it then never turns off.
    So my question is after seeing many temperature limiters and a “switch” which looks like a resistor which part actually is responsible for turning it On and Off again?
    #491053
    may well be item 10006705
    resistor heats up and activates thermostat which turns on fan
    when oven off it cools down slowly allowing fan to run on
    to prove its the problem you need to run with the lid off and disconnect one wire from the stat when it sticks on
