Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › neff oven cuts out
- This topic has 16 replies, 5 voices, and was last updated 6 months ago by
suedehead1.
October 4, 2025 at 6:04 pm #103595
suedehead1
ParticipantHB632GBS1B/63 built in single oven it heats and fan goes then it stops heating and fan stops going but display still lit,
suspect pcb but was open to any ideasOctober 4, 2025 at 7:13 pm #493867electrofix
Moderatormost ovens have a cooling fan. not the fan inside the oven it blows cold air around the inside and out over the door to keep things cool. if the fan fails then oven will do exactly what your is
if you remember when the oven is working correctly the cooling fan carries on running for 10 mins or so after the oven is switched offDave
October 7, 2025 at 7:00 am #493868suedehead1
Participantthanks Dave i never checked that , i will get another look at it.
October 14, 2025 at 4:59 pm #493869DPDOM
ParticipantI’ve had earth leakage element cause this
October 22, 2025 at 6:28 am #493870suedehead1
ParticipantHi again, i changed the cooling fan it made no difference, checked for earth leakage all ok.
October 22, 2025 at 9:15 am #493871electrofix
Moderatoris the cooling fan running
assume you checked thatDave
October 22, 2025 at 4:34 pm #493872suedehead1
Participanthi yes its running and continues to run after oven switched off
October 22, 2025 at 5:22 pm #493873electrofix
Moderatorok did you check if the overheat stat had tripped after it cutout ?
also above, never had it myself DPDOM says he had element problems causing this so thats worth a look
And lastly you said Neff but its come up as Siemans
October 23, 2025 at 5:43 am #493874suedehead1
Participantyour correct it is siemens i will go back and check overheat stat, i thought if it cut out everything would go off
October 23, 2025 at 8:51 am #493875electrofix
Moderatoron some cookers yes but others no so worth checking
pull one wire off and switch on to see if clock goes off. if yes it cant be the stat
DaveOctober 23, 2025 at 8:37 pm #493876kaibart
ModeratorFrom what your explaining its a control module fault part number 11029688 £120.33 with bosch
October 23, 2025 at 9:20 pm #493877Hollytree_Technical
ParticipantWhat about the door switch? Some ovens stop the fan and element when it thinks the door is open to save energy – I don’t know if the switch is on the mains voltage side or the low voltage side but if it is on the low voltage side then it may not take much resistance for it to think that the door is open.
Jem
October 25, 2025 at 8:18 am #493878suedehead1
Participantgoing back this morning these ovens are becoming over complicated
October 25, 2025 at 10:24 am #493879electrofix
Moderatorsuedehead1 wrote:going back this morning these ovens are becoming over complicated
well agree there
got an oven over 50 years old , simple thermostat still works okdont use it much and do intend to swop it when i do the kitchen
its that old that the knob operates a bevel gear to turn the horizontal rotation to vertical rotation and a rod goes down to a rod stat. Was reconditioned when my dad bought it in 1970
thats when Belling cookers lasted lol
October 26, 2025 at 11:02 am #493880suedehead1
Participantback out to the oven, once it gets hot there is an earth leakage at the fan oven element, going to change it and keep fingers crossed.
tried disconnecting safety thermostat and the oven still worked no heat, bypassed door lock it still cuts out,
nightmare job. -
