neff oven cuts out
Viewing 15 posts - 1 through 15 (of 17 total)
  • #103595
    suedehead1
    HB632GBS1B/63 built in single oven it heats and fan goes then it stops heating and fan stops going but display still lit,
    suspect pcb but was open to any ideas
    #493867
    most ovens have a cooling fan. not the fan inside the oven it blows cold air around the inside and out over the door to keep things cool. if the fan fails then oven will do exactly what your is
    if you remember when the oven is working correctly the cooling fan carries on running for 10 mins or so after the oven is switched off
    suedehead1
    thanks Dave i never checked that , i will get another look at it.
    #493869
    DPDOM
    I’ve had earth leakage element cause this
    #493870
    suedehead1
    Hi again, i changed the cooling fan it made no difference, checked for earth leakage all ok.
    #493871
    is the cooling fan running
    assume you checked that
    suedehead1
    hi yes its running and continues to run after oven switched off
    #493873
    ok did you check if the overheat stat had tripped after it cutout ?
    also above, never had it myself DPDOM says he had element problems causing this so thats worth a look
    And lastly you said Neff but its come up as Siemans
    suedehead1
    your correct it is siemens i will go back and check overheat stat, i thought if it cut out everything would go off
    #493875
    on some cookers yes but others no so worth checking
    pull one wire off and switch on to see if clock goes off. if yes it cant be the stat
    kaibart
    From what your explaining its a control module fault part number 11029688 £120.33 with bosch
    #493877
    Hollytree_Technical
    What about the door switch? Some ovens stop the fan and element when it thinks the door is open to save energy – I don’t know if the switch is on the mains voltage side or the low voltage side but if it is on the low voltage side then it may not take much resistance for it to think that the door is open.
    Jem
    #493878
    suedehead1
    going back this morning these ovens are becoming over complicated
    #493879
    suedehead1 wrote:going back this morning these ovens are becoming over complicated
    well agree there
    got an oven over 50 years old , simple thermostat still works ok
    dont use it much and do intend to swop it when i do the kitchen
    its that old that the knob operates a bevel gear to turn the horizontal rotation to vertical rotation and a rod goes down to a rod stat. Was reconditioned when my dad bought it in 1970
    thats when Belling cookers lasted lol
    suedehead1
    back out to the oven, once it gets hot there is an earth leakage at the fan oven element, going to change it and keep fingers crossed.
    tried disconnecting safety thermostat and the oven still worked no heat, bypassed door lock it still cuts out,
    nightmare job.
