Neff Oven dead part from oven lamp flashing on/off
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff Oven dead part from oven lamp flashing on/off
  • #101430
    oscar123
    Neff B57VS24H0B/52 panel dead after turning on power.. after around a minute oven the oven lamp flashes on and off.
    It is the one with a steamer so probably picking up some kind of fault but doesn’t want to talk about it 🙂
    #484711
    there is definately something going on. could be a fault code as found this
    https://www.youtube.com/watch?v=-QeohmQT3PU
    the one in the video seems to flash twice a few times then it flashes once from there on giving me the impression its not a fault code as I would have expected it to stay the same
    as a long shot disconnect all you can. elements, steam module and see if anything changes
    oscar123
    Hi Dave, thanks for the reply.. I can see what you mean about the one on the video but this does not pause at all, I did think it might so watched and counted but it was consistent. I have had to tell him to ring Neff as it would the appear they have found a way to conceal faults and keep the work in house! 🙁
    #484713
    did you trace the lamp back to the board and see if the power supply to the lamp is going on and off
    if it’s not then it’s just the lamp
    oscar123
    The panel is dead.. no display at all
    #484715
    its got all the makings of a board fault
    the problem is which board or both
    did you try disconnecting and re connecting the ribbon cable between the 2 boards to rule out bad connection ?
