Neff oven door sealing problem
Home Forums Public Support Forums Spare Parts Help Neff oven door sealing problem
  • #29352
    reedwv
    Door doesn’t seal/close properly at the top.
    Model Nr: U1420N0GB/01 FD: 7812
    Seems to be a common problem most likely needing two new hinges.
    Please confirm the part nos are 260797 & 260798. Also Cost?
    Also is it likely that the door bearings, 154767, could need replacing as well?
    edit: based on posts by BigBadDad I’ve ordered hinges anyway
    Will post result.
    #222849
    gegsy
    Re: Neff oven door sealing problem
    Yes you have quoted the correct hinges and you may need the hinge receivers due to age of appliance, please note that there is a part change and the correct number is 172647 for left or right.
    reedwv
    It worked! Luckily still had oven install manual which told me how to take door off.
    Once T60 screwbit was found took 15mins to change hinges, including cleaning inner glass surfaces.
    Door now seals nicely and oven heats up quicker.
    Good service, thanks
