Neff Oven Enamel Corrosion
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Oven Enamel Corrosion
Viewing 1 post (of 1 total)
  • #101526
    Green_Nigel
    Hi Folks,
    I have a Neff N50 Built-in double oven U2ACM7HN0B and for the most part I’m pretty happy with it however I have had to consistently get Neff out to look at because of the corrosion at the small lip in front of the door of the main oven. In fairness Neff have been really good about it and promptly replaced it twice however a pattern seems to be emerging of the corrosion happening at exactly the same place after around a year of use. The oven cavity is pyrolytically cleaned regularly and spillages are cleaned up after use using just a damp non-abrasive cloth so no prohibited chemicals or abrasives have been used. Besides the area affected isn’t one where spillages typically happen anyway although it is an area that the pyrolytic clean doesn’t have any impact.
    As it is the same place that has been affected I’m beginning to suspect that this is an inherent problem with the oven but don’t really want to get into an annual cycle of calling Neff out to look at it.
    Has anyone else seen a similar issue and if so what was the outcome with Neff?
    Cheers!!
