Neff Oven fan not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Oven fan not working
  • #22400
    StevieT
    Can anybody help please?
    Neff TypB-AP22-7
    E-Nr B1430N0GB
    240v-50Hz
    195,311060
    The fan on the rear of the main oven started to work intermittently and has now completely stopped. Everything else, including the main heating elements (oven & grill) work fine.
    Does anybody have any ideas?
    #194821
    gegsy
    Re: Neff Oven fan not working
    The part you need is here http://www.ukwhitegoods.co.uk/modules.p … cts_id=447
    Regards
    StevieT
    I’ve taken off the fan motor and there appears to be nothing obvious at fault. The fan turns freely by hand.
    I have also run a meter across the two terminals, turned the oven dial to the “ON” position but nothing shows. Could this be because it is a DC motor or should i still expect some reading?
    Any ideas would be most welcome.
    #194823
    StevieT
    Thanks Greg,
    Is it expected that i have seemingly no voltage from the two terminals connecting to the fan motor?
    If so i’ll simply order a new fan motor as per your suggestion
    Thank you for your assistance.
    #194824
    gegsy
    Under no circumstances should you be live testing :nono:
    Unplug appliance before attempting any measurements and/or repairs.
    The motor is fed by an AC feed FYI.
    Make sure the clock is set and also on the “Manual” hand symbol setting.
    Usually you will hear a low hum in the cavity when turned to fan oven setting, indicating the motor is semi seizing or windings have gone weak.
    Regards
    StevieT
    Greg,
    Thank you once again. I had forgotten to re set the clock and now can confirm that the voltage is present.
    Need to order a new motor i think
    Thank you once again for your help.
    #194826
    gegsy
    Hi stevie
    You welcome but please be safe and no more LIVE testing please 😉
