Neff oven fuses when slamming door
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff oven fuses when slamming door
  • #97597
    Richard Jones
    Morning,
    Bit of a strange one. Top electric oven kept tripping the fuse, so 1st port of call was to replace the element.
    So I decided to check it if was the top or bottom, first by selecting both elements on, then top grill only.
    Results were both tripped fuse, top only was ok. So went to double check, and neither of them tripped…
    So next morning i let it cool down to see if it was the mini fan that was causing issues. All fine.
    UNTIL – i slammed the door. Then it tripped again. Did this a couple times, and same result every time. Gently closing was fine, but letting it flip shut on the hinges caused it trip.
    I’m goingt o take it out this afternoon and have a look, but is there any hypothesis on what it could be?
    TIA
    #468574
    well could be all sorts but without a complete Enr and FD number I cant look up the parts diagrams
    Richard Jones
    It’s a U17M24.0GB
    Just to add, I replaced the bottom oven thermostat just before Xmas, so I have had it out and the back off before, wondering if it’s something in doing that? Was fine up until about 3-4 weeks ago.
    #468576
    that number is not correct, Get um17 but then add M and it fails.
    Richard Jones
    that’s better you reversed the numbers
    was wondering if it had a door sw but does not seem to
    go with your first idea check the wires. look at the loom where it turns corners. if it is an earth fault it probably on the neutral as its not going bang
    Richard Jones
    Cheers, will have a poke around this afternoon
    #468581
    Richard Jones
    Solved!
    Tested and it started tripping on the top+bottom only.
    After a bit of poking i noticed the replaced thermostat wire (which is about 5x longer than needed) had started to unwind. Bingo – it had been in and around the spade connector to the bottom element and was touching it. Quick cable tie and testing later, problem sorted 🙂
