neff oven green fault light
  • #59208
    kevinlewis
    B 1691 N0GB/01 FD 8101
    Set the oven at any temp either on fan or conventional heat. It starts heating and the heat indicators rise from the bottom segment on the indicator to the 4th ,”top” indicator in about 5 minutes. Then it bleeps once and a green indicator then comes on to tell you that it has not reached temperature correctly.
    could it be the NCT from the control PCB or is it more likely the PCB itself?
    This oven does not have the common EGO type Thermostat .
    #337365
    kevinlewis
    Re: neff oven green fault light
    As I have had no advice on this occasion I have told the customer to get in contact with BSH as I did not want the problem of ordering the sensor only to find it could have been the PCB. Thanks anyway.
