Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff Oven/Grill Controls getting too hot
- This topic has 11 replies, 3 voices, and was last updated 18 years, 4 months ago by
tonyb61.
November 24, 2007 at 12:00 am #32472
tonyb61
ParticipantWe have had an integrated Neff 1 1/2 double oven grill U1661 for 5 years, which has recently developed an odd fault. When we use the grill in the smaller upper oven the front panel controls get really hot, too hot to touch, and the grill control knob has deformed with the heat. What is likely to cause this ? A cooling fan that has stopped operating, or faulty grill thermostat ?
November 24, 2007 at 12:08 am #235255gegsy
ParticipantRe: Neff Oven/Grill Controls getting too hot
More likely to do with the cooling system IMO.
When you switch on the oven, do you feel a flow of air from above the doors in each cavity ? If so then the cooling system is ok. If not then either a faulty cooling fan/s or control relay for the fans 😉Power off if you are to investigate :plug:
November 24, 2007 at 1:30 am #235256BSH-MAN
You are grilling with door closed I hope.
November 24, 2007 at 9:44 am #235257tonyb61
gegsy wrote:More likely to do with the cooling system IMO.
On the main oven I can feel a small flow of cool air from the vents just above the door. but not from the vents above the small oven/grill.
Can you normailly get to these items without removing the oven form the housing unit ?November 24, 2007 at 9:48 am #235258tonyb61
BSH-MAN wrote:You are grilling with door closed I hope.
For the five years we have had the unit, when we use the gtrill, mainly for toasting, we never have shut the door and the controls did not get hot, until now ? Is it wrong to do this ?
November 24, 2007 at 9:48 am #235259gegsy
Unfortunately you will have to extract to gain access.
If you can give the full model number off the oven, that will be handy in correctly identifying parts you may need 😀
BSH-MAN made a valid point though, you must grill door closed as failure of cooling fan would not result in a deformation of knobs under normal operation 😕Greg
November 24, 2007 at 10:59 am #235260tonyb61
gegsy wrote:Unfortunately you will have to extract to gain access.
GregModel No is E Nr U1661N0GB FD Nr 8201
November 24, 2007 at 11:04 am #235261gegsy
Cooling fan on both the GB/01 and 02 is 140210. If required the spare is available from spares@ukwhitegoods.co.uk 😉Greg
November 24, 2007 at 12:00 pm #235262tonyb61
gegsy wrote:Hi
Do you think the fan is more likely to be faulty than the control/relay ? The other fan comes on ok so I guess the fan is more likely ?November 24, 2007 at 12:14 pm #235263gegsy
A quick test with a multimeter on ohms setting on fan terminals (with the power off to appliance) should indicate whether its ok or faulty.
Although sometimes they can read ok but they cannot turn due to worn bearing/s or grease ingress causing restrictions 😕Greg
November 24, 2007 at 5:59 pm #235264tonyb61
gegsy wrote:A quick test with a multimeter on ohms setting on fan terminals (with the power off to appliance) should indicate whether its ok or faulty.
I checked and the fan resistance was fine. I removed it from the oven and powered it from the mains. I could see it was rotating slowly and sometimes almost stopping. I took it apart and cleaned it up and it runs fine now.
So for the moment looks good.
Thanks for the help.November 28, 2007 at 10:25 pm #235265gegsy
Glad you sorted but for future readers safety please do not carry out any live testing of any kind on any appliance, there really is no need :plug:
