Re: neff oven problems
not sure I should take advice from homer Simpson but you seem to know what you are talking about.
I have really taken this as far as I can at DIY level. May need to get engineer in but wanted to remove burnt out element first to see if that was the only cause. Fitted genuine spare no fuss ( well one of the tags was tight to get on and off, but better that than loose and arcing ) but on start up clearly not heating up. Could there have been another fault with thermo cutout that would cause the previous element to have blown or is it just coincidence ?
Should I just swallow my pride and get a service@ engineer to take a look ?
Thanks for quick reply
