NEFF Oven Problems
  • #50480
    tony1955
    Hi Guys
    I’ve just fitted a new oven element to a Neff B1542 fan assisted oven. Everything works well, oven heating up and grill works.
    😕 However when I reset the clock the oven internal light comes on and wont go out despite all controls on off.
    I had replaced the bulb which blew witht he element .
    Any suggestions would be appreciated
    Tony
    #304936
    Re: NEFF Oven Problems
    Selector switch will be damaged.
    tony1955
    Thanks penguin, that makes sense as the red oven light is also now on permanently too!
    I’ve a had a ook on the web and can’t find a relacement part so I guess its a new oven!
    All the bgest
    Tony
    #304938
    Look on http://www.bshcustomerservice.com – full parts listings and diagrams. You will need the full eNr number though.
    tony1955
    Thanks- found it and found the part.
    Next question is how do I access the selector?
    Do I remove the fascia panel ( four fixings beneath the the front lip)
    or go at it by removing the top casing which is attached to the main oven housing?
    Regards
    Tony 😀
    #304940
    tony1955
    Hi Guys
    Please ignore my last question, access was obvious once I got the oven out.
    I can’t detect any damage to the selector switch, all looks normal to me and the contacts seem to move properly but there is current to the internal lamp and the oven temp lamp in the off position.
    I can’t see how to remove the switch without taking off the front panel,knob and fixing plates which is a a bit daunting.
    Any advice is welcome.
    Regards
    tony
