Neff Oven Stopped Working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Oven Stopped Working
Viewing 15 posts - 1 through 15 (of 15 total)
  • #14635
    megamarty
    I have a Neff AP22-7 Oven about 5 years old. My wife switched it on yesterday and it tripped the fuse. On restarting it there is no heat from the oven or the grill. The clock, light and fan all work. The 2 elements look OK.
    Could it be that both elements have failed simultaneously or could it be something else?
    #160237
    gegsy
    Re: Neff Oven Stopped Working
    hi megamarty
    We need full model number please. Jot all umbers off ratiing plate and we will be able to assist you further.
    megamarty
    B132OWOGB/01 FD 8003
    B AP22-7 5750313103
    Hope this helps
    #160239
    gegsy
    I take it you were on the fan oven selection when it blew a fuse??
    If so its most likely the circular element has failed -P/no 499003.
    The top element you can see is for the grill only and would not be activated under fan assisted cooking.
    See spares@ for part/s you may require.
    megamarty
    Thanks for the quick reply.
    When switched to grill only, the grill element does not work.
    Would the circular element failure cause the grill element to stop working?
    #160241
    gegsy
    The failure of the fan element would bare no connection to the grill element. A more common factor of the two is in play.
    Considering facts of your fault may I suggest repairs@ to get an accurate diagnosis.
    megamarty
    Because the grill element and the oven element both don’t heat up, but the fan, clock and light works, would this suggest a faulty thermostat?
    #160243
    gegsy
    If they share the thermostat yes or possible selector melt down.
    megamarty
    Update:
    Changed the Oven element, but STILL no heat.
    Everything else seems to be OK, Fan, Light, Clock work, I can swith between oven and grill, and I hear the thermostat click when I turn it on.
    I’ve pulled it out and had a look inside, can’t see anything obvious and it doesn’t look like there are that many things that can go wrong.
    Do you think I should try replacing the thermostat, and if so, does anybody know the part no. and cost?
    Many thanks
    #160245
    gegsy
    Hi Marty
    Its graspin at straws time, I would seriously look at repairs@ as this really as far as we can go without seeing the appliance.
    regards
    megamarty
    Thanks Greg
    I’ll try and get an engineer to have a look.
    There are none listed in my area in repairs@
    Does anybody know of any in the Ayrshire area KA3?
    #160247
    We can look at it for you although we don’t list Neff in Repairs@.
    If you give Craig a call in the morning he should be able to help on 0845 226 2507, but please tell him I okay’d it. 😉
    megamarty
    Another Update:
    I have managed to identify the problem, I hope
    At the rear of the oven is a small silver button shaped part next to a letter R that looks like its fried. It is connected between the thermostat and the main oven element.
    On it is printed
    13A/250v
    7A/ 400V
    T180/1
    and on the other side
    Z42/43
    10/230
    Any ideas of what it is and if I can get a replacement
    #160249
    superfix
    Sounds like the overheat TOC has died a death.
    I’m sure Dave can sort you one out.
    #160250
    Limiter – p/no 151326, about £7 + vat IIRC. Email to spares@ukwhitegoods.co.uk for ordering and confirmed pricing.
