NEFF Oven Timer
  • #71944
    JJ0N
    Hello,
    I have a NEFF Double Oven. The Timer has stopped working.
    Normally when I turn the timer on the procedure is to:
    (1) Turn the relevant oven on
    (2) Set the temp required
    (3) Set the Timer
    When the Timer kicks in in turns the oven off till the appropriate time.
    That suggests to me that the power for the Oven Elements pass through the timer in some way presumably via a Relay.
    At the moment turning the timer on has no effect.
    I am wondering is there a fuse or something protecting this (apparently) electronic timer?
    Also I bought a NEFF Timer a while ago for a previous Oven. It does not fit this one but I wonder if there is a specific part (Relay) at may be common.
    Many thanks
    #382859
    Re: NEFF Oven Timer
    Model number and enr number will help greatly.
    Bryan
    #382860
    JJ0N
    Re: NEFF Oven Timer
    Hello,
    I think the Model Number is U1442N0GB/03
    or FD8605
