Neff oven tripping RCD
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff oven tripping RCD
  • #22849
    cutlp
    Our Neff Circotherm oven (model=GB-1056.71 HCS Enr=195304875 FNr=6304) has given us nearly 20 years of almost trouble free service but is now tripping our 30mA RCD. This is caused exclusively by the main oven (i.e. not the grill) and only occurs when the thermostat opens or closes, so it is not related to the fan.
    Clearly there is a small intermittent leak of current to earth somewhere.
    Typically it trips once or twice during each use, so the oven is still useable. In fact, apart from this, the oven is as good as new.
    I am tempted to replace the element – I did this once before many years ago when it failed (on Christmas Eve would you believe!) but of course it may not solve the problem.
    ❓ Could the leakage of current be coming from the thermostat itself?
    ❓ Can anyone offer any advice?
    Many thanks.
    #196311
    Re: Neff oven tripping RCD
    Fan oven element most likely culprit…….. You need a megger to test for sure. Neff p/no is 083517, about £41 + Vat etc, or NF1413 is a decent pattern replacement for rather less. Contact spares@ukwhitegoods.co.uk for prices and ordering.
    Stay safe, power off when investigating.
    cutlp
    Thanks Penguin45
    Fitted new element today. Works OK but we may not know whether the new element has cured the RCD tripping problem for several days or even weeks. If it hasn’t then we will just live with it until we re-do the kitchen and get a new oven – it is about 20 years old after all!
    Thanks again
    #196313
    cutlp
    *** Update ***
    One year on and everything is still OK – the RCD has not tripped once in 12 months.
    Thanks.
