Neff Oven U1421 – no heat in main oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Oven U1421 – no heat in main oven
  • #47722
    Congers
    I have a Neff U1421 N0GB/01 double oven. The element went with a bang and this was duly changed. I was still getting no heat, but the fan and the lights worked OK. I then changed the thermostat as it had stopped ‘clicking’, (like the small oven’s did), when turned off and on. But I am still getting no heat!! Can anyone point me in the direction of what could be the problem now? Is there a safety cut-out or thermal fuse that needs changing? Thanks.
    #294368
    Re: Neff Oven U1421 – no heat in main oven
    P/no 151326 – limiter – may have failed. White ceramic block next to the fan motor, should read normally closed when metered.
    Power off first, please.
    Congers
    Thanks Penguin, will check there next.
    #294370
    Congers
    Update – have checked the limiter, and that too has blown. On order now. Thanks Penguin.
