Neff Oven U1442
  • #87186
    nefftrouble
    How do I get to my Timer on my Neff U1442 Oven to replace it?
    Thanks.
    #434172
    Re: Neff Oven U1442
    most times through the top
    would know more but would need complete model no
    anyway what wrong with it as the only one i looked at was £111 so you dont swop it for no reason
    also you should be able to disable it and bridge it. thats if you dont use it
    nefftrouble
    Re: Neff Oven U1442
    Thanks for the reply.
    You have guessed correct, we had a short circuit somewhere which tripped the Earth Leakage trip, since then the timer has never worked correctly and every time I reset the time, after a few hour it trips out and makes a wirring noise, tried all sorts of settings but nothig seems to work.
    Therefore we never use the timer so thought if i can get inside I would disconect it, to save all that money!!
    The numbers I can find are as follows:
    E Nr U1442NOGB /10 FD8806
    HBB-AP60-7
    Any help or advice would be appreciated.
    #434174
    Re: Neff Oven U1442
    if you take the top off and take a photo of the timer connections and post it on here there is a good chance i can tell you which ones to bridge
    nefftrouble
    Re: Neff Oven U1442
    Will do that tomorow, thanks for advice.
    #434176
    nefftrouble
    Re: Neff Oven U1442
    Photo as requested.
    #434177
    Re: Neff Oven U1442
    form the look of that i would say
    the relays that control the ovens are on the right (2 white blocks with shrack written ontop)
    so join brown and black from relay on left
    and seperately join pink and red from relay on right
    you can get piggy back connectors to help as below
    nefftrouble
    Re: Neff Oven U1442
    Many thanks for the info, connections now changed and all seems to work Ok without any problems, much appreciate your time.
