neff oven ui420ovgb/o1
  • #58555
    adv
    bosch wantin £90 for the main oven fan motor pricey. anywere else cheaper lads?
    #334914
    aqualectric
    Re: neff oven ui420ovgb/o1
    MTR213 from Qualtex @ £31.37 + VAT will fit. Looks different at first but when the old one is removed, the holes on the motor mounting panel line up perfectly with the triangular mounting plate. Just move the motor around until they line up. 😉 The 3 screws holding the original motor will be too long so just swap them with the shorter back cover screws (making sure the longer screws are fitted in the corners of the back cover).
    Hope that helps,
    Steve.
    #334915
    adv
    ok thanks for that mate 😆
