Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Neff oven won’t heat up
- This topic has 5 replies, 3 voices, and was last updated 12 years ago by
stuartornum.
April 23, 2014 at 7:09 pm #80420
stuartornum
ParticipantModel: B1421N2GB /05
Hi All,
We cleaned the oven a couple days ago and haven’t used it since – went to turn it on just now and it will not heat up…
The following seems to be ok:
Power to the oven looks good – the clock is on and switching the oven on makes “a” fan spin.
The thermostat seems ok too – I turn it past 20ish degrees and I get a click ( I believe that is the test…??)What doesn’t work:
The oven itself will not heat up – I’m not sure if there is a fan where the element is inside the oven.. I cannot see one moving.
The grill does not heat up either.Any help would be very much appreciated.
April 23, 2014 at 10:10 pm #412784kwatt
KeymasterRe: Neff oven won’t heat up
Most probably just the fan element that’s popped.
The back panel in the oven should come off, usually a couple of screws or so to release, then from what I can see it should be this element if I’m right:
http://shop.ukwhitegoods.co.uk/2044-bos … en-element
Once you get to that it’s easy enough checked with a multi meter.
April 24, 2014 at 6:53 am #412785Martin
ParticipantRe: Neff oven won’t heat up
No fan heat, no grill heat having just cleaned the oven could simply mean you’ve accidentally switched the oven to ‘AUTO’? Try switching the oven timer to ‘MANUAL’?
April 24, 2014 at 7:23 am #412786kwatt
Sorry, I missed the grill bit.
April 30, 2014 at 8:07 am #412787stuartornum
Martin wrote:No fan heat, no grill heat having just cleaned the oven could simply mean you’ve accidentally switched the oven to ‘AUTO’? Try switching the oven timer to ‘MANUAL’?
Sorry, I didnt get a notification for this comment – I bought a replacement element – no difference…
Right, so we may have switched it to “AUTO” – how do I switch it to “MANUAL”?
I’ll try and find a manual online and see if that sheds any light.
Thanks!
April 30, 2014 at 11:05 am #412788Martin
To switch from Auto to Manual press this button……..
