Front fan off – motor connections and ‘horseshoe’ clamp removed . Rear ‘kidney’ panel off and motor should release backwards – This pulls the motor shaft back allowing you to slip the new belt over the shaft end onto the pulley. Just make sure the belt is positioned correctly on the pulley and doesn’t rub on the larger belt.
