Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff r4381x1gb/01 condensor tumble,, urgent help please guys
- This topic has 8 replies, 5 voices, and was last updated 18 years, 7 months ago by
MANDELLS.
August 14, 2007 at 2:18 pm #29775
MANDELLS
ParticipantI am having problems with the said t/dryer, it seems to be a top of the range all singing and dancing one with a small led delay display that is displaying 2 lines(imagine the number 8 with only the middle display showing) and the dryer will not start or do anything although when you turn the selector knob the lights will change to show whioch program has been selected but just dead apart from that, i really dont want to order a board (pt no 267397) at bundles of dough
Has anybody got any ideas, is it a conmmon fault??August 14, 2007 at 4:50 pm #224688onecallpaul
ParticipantRe: Neff r4381x1gb/01 condensor tumbl,,, urgent help please
Hello son, has it got a light inside sometimes the cover comes off or gets damaged causing steam to get into the facia, just a thought.
August 14, 2007 at 5:21 pm #224689MANDELLS
Hello mate, No def not that, any other ideas folks????
August 14, 2007 at 7:17 pm #224690superfix
Yup, pretty sure someone has set the child lock 8)
See instruction book for how to turn off, IIRC it may be hold start for four seconds or so.
HTH
August 14, 2007 at 8:36 pm #224691gegsy
I have tried to decipher the pigeon English translation but to no avail.
Have a go yourself 😆I block children’s
To prevent not authorized use of the device (p. ej. in laundry rooms of collective use) will be able to block the device across the electronics.
It will do that I turned out to be impossible to start the device – after disconnecting the dryer the activated blockade will be supported.
It will not be possible to block a program that is executed.Introduction of the electrical blockade:
1. To connect the device
2. To keep the key touched To “select” (as minimum during 6 seconds) – in the display of 7 segments will be visualized “-“. :rolls: GregAugust 14, 2007 at 8:41 pm #224692gegsy
If I was to have a guess I would say keep “Start” button depressed whilst powering up and wait for some sign of unlock 😕
August 15, 2007 at 6:05 am #224693bobokines
ParticipantRe: Neff r4381x1gb/01 condensor tumble,, urgent help please
I had similar problems a few weeks ago…
http://www.ukwhitegoods.co.uk/modules.p … t=neff+bob
In my case the damn thing came back to life on it’s own. However I did discover that the child lock is activated and deactivated by depressing the select button for 6 seconds.
Bob
August 15, 2007 at 4:20 pm #224694MANDELLS
You guys are the Mutsnuts!!!
CHILD LOCK CHILD LOCK CHILD LOCKone very happy customer, one very happy engineer and one not so happy BSH man that had the module ready for dispatch.
THANK YOU THANK YOU THANK YOUAugust 15, 2007 at 7:08 pm #224695bobokines
I guess you’re happy then 😉
Bob
