After some advice if possible, I am going to replace the bearings on this dryer, I have purchased the bearing set and the seal set for front. What I need to know what is the best way to remove the drum, Take the back off or the Front panel
not sure which is best !! I am sure someone will know. thanks John
hi i remove the sides and back panel unhook the belt and take the drum out fit the new seal and bearing then rebuild do not take the front off
good luck
