Neff R4381X1GB dryer
  • #61557
    kitchencare
    My dryer has a problem.
    No matter which programmes you select, the LCD display count down goes down to zero after roughly 3 mins. I called Neff and they advised that it could be the sensor.
    I stripped it down, cleaned all excess fluff etc from filters, heat exchanger etc and replaced the sensor but it is still doing the same thing.
    Is it the display PCB that is causing the problem or the main module to the right?
    #346565
    superfix
    Re: Neff R4381X1GB dryer
    Are you testing it empty ?
    #346566
    kitchencare
    yes… it’s stopping because it senses it’s empty?
    normally only ever used to dry dog blankets a couple of times a week
    #346567
    nomadPaul
    Yes , if you do a sensor dry cycle empty , it will shut down as it thinks everything’s dry.
    With a damp load in , Does it count down , and continue to count down without the drum actually turning ? If yes , then its most probably the door lock .
    …..oh , and don’t forget to give the paddles inside the drum a really good clean.
    #346568
    kitchencare
    Works fine with damp load, heats, drum turns but beeps sooner than countdown finishes?
    Is it important to keep the paddles clean? Damp cloth ok for that?
    #346569
    nomadPaul
    The paddles can get a thin limescale coating so a wipe with white vinegar has been recommended to me .
    When your machine beeps , do you get any other indications with it i.e flashing lights or anythiing in the LED display ?
    #346570
    kitchencare
    Nope, just goes to zero and beeps. 🙁
    #346571
    superfix
    You have cleaned the condenser THOROUGHLY haven’t you.
    #346572
    kitchencare
    Yup totally clear, when stripped I vacuumed out all the excess fluff from the inside too. Condensor cleaned with power shower so blasted all the excess out. I also need to replace the door lock button at the bottom that tells the lock it’s shut(the round bit on the bottom right) is there an easy waymto do this or just to click it out of place
    Thanks guys appreciate your help
