sounds like a classic ‘impellor jug’ fault.
Its the flow rate meter – part number 424099.
It will cause the machine to fill/drain/fill/drain at cycle start and the ‘check water’ light to illuminate (The tap symbol)
Basically , the impellor jug isn’t sending the correct signal to the control module so the appliance has no idea what rate the water is incoming…..this causes overfilling – hence the drain out portion – as it can’t sort its water level out.
