Neff S4430W0 GB
  • #35774
    Dishwashin_by_hand
    Our dishwasher does not fill nor does it proceed through a cycle without manual advance of the programme dial at a number of points in the cycle.
    I have referred to:
    viewtopic.php?f=33&t=21993
    which describes my problem to a tee. Also the related response at:
    viewtopic.php?f=33&t=21915
    and have cleaned out the water inlet hose as suggested. However the fault described is not resolved.
    Is it time to buy a new dishwasher or is there another possible solution?
    Excellent forum by the way.
    Thanks all.
    #248039
    gegsy
    Re: Neff S4430W0 GB
    At the rear there is a pop out rectangular plate with the fill valve spout coming out of it.
    The fill valve solenoid is behind there. It should read app 2-3 kohms.
    Power off before you attempt any fault finding.
    Dishwashin_by_hand
    Re: Neff S4430W0 GB
    Thanks Greg for the prompt response 😀 .
    I don’t have a meter to test the solenoid (and I’d probably be out of my depth anyway).
    In your view, is it worth having an engineer look at it or would it be just as well to think about a new machine? In which case, I have been looking at the Neff S44E43WOGB. Your thoughts?
    Thanks again.
    #248041
    gegsy
    Re: Neff S4430W0 GB
    Its an integrated quality item and to replace, off the top of my head app £500 – £600 😕
    Give repairs@ a go on the LHS menu 😉
    Dishwashin_by_hand
    Re: Neff S4430W0 GB
    Thanks Greg. Will do. 🙂
