Integrated Appliances!!!
The dishwasher does not fill. I have checked the aquastop, and there is no supply to the solenoid valve. Does anyone have a wiring diagram for above pleeeeez? I suspect module problem.
1/ Is there any water in the base ?
2/ Check that the clear ribbed pipe and its system (goes from metering unit to sump at the front) are clear from gunge as it may have activated the level switch prematurely.
Cheers Gegsy, Yes, done all that, no water in base, front hose clear, no cable harness damage which is rare on these machines. Just no supply, suspect timer fault but could use wiring diagram or it’s a strip down job to follow cables, YUK.
Steve
