neff S4453n0gb/13
  • #66982
    clockworkone
    what kind of a job is it to fit heater(491755) on this one.not seen it yet but fault reported is m/c wont stop until you switch it off.
    #365817
    spimps
    Re: neff S4453n0gb/13
    Busy 90 minutes or so depending on if its built in,wash chamber has to be split from the plastis base,not the easiest but OK to do.
    #365818
    clockworkone
    many thanks for reply.paul
    #365819
    Read Martin’s opening post in, “Tips, Tricks and Shortcuts.”
    Mike.
    #365820
    spimps
    Doesn’t get any better than Martins post,spot on.
    #365821
    nomadPaul
    A faulty / open circuit heater is NOT the most common cause of no heating…..low water levels are . Check the pressure chamber/fill hose first .
