Could someone please tell me how the microswitch on the heater works and if it comes with the heater ? It’s open circuit and I’m not familiar with these dishwashers.
Allan
Water pressure forced through the heater by the circl. pump and operates the bellows that operates the microswitch. No flow then the microswitch returns to its O/C position.
Yes it is included with the heater. Also the safety stat, NTC and water point diverter included as one complete unit.
If that were the case then the spray arm wouldn’t rotate as they should. On these only one spray arm rotates at any one time don’t forget as it has a water point fitted.
