Neff s4840x0gb/06 stopped mid cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff s4840x0gb/06 stopped mid cycle
  • #32063
    gixerk1
    hi everyone
    my nef dishwasher was stopped tonight mid cycle by my wife due to a blocked sinked i think she pressed a few buttons to many to try to start it again i have bailed the water out of it and sink is now unblocked i have drained pipe from dishwasher to sink pipe
    but no joy it has worked perfectly up to now nothing in manual seems to help any advice would be greatfully received
    thanks
    tim
    #233480
    gegsy
    Re: Neff s4840x0gb/06 stopped mid cycle
    There should be something in the manual regarding pressing certain buttons down to engage the hidden mechanical timer to abort and reset itself:? 😀
    gixerk1
    hi
    the only thing in the manual is programme interupt andspeed up programme both have been tried but to no avail
    tim
    #233482
    There will be two programme selector buttons with a dot under them. Press them both together until the drain pump cuts in. It should run for one minute; then the computer is reset. Switch off, reprogramme and see what happens.
    gixerk1
    i have 5 buttons 1 main on/off and 4 programme buttons
    65 intensive 65 normal eco 55 quick manual states to quick finish press 65 and 55quick this has no effect no buttons have dot as mentioned as it is a built in model would the dots be under fascia i have also removed a sticker near buttons and there is no dot either
    just a thought could some gunge get down the dishwasher waste pipe cannot blow through it but i dont know if that is due to part of the cycle
    tim
    #233484
    gixerk1
    have had another look today no dots under buttons have removed wood facsia nothing there have tried everything in manual still stuck im afraid also no apparent blockages etc
    tim
    #233485
    There seems to be a bit of confusion over the programme buttons here? In fact your machine is NOT an electronic controlled machine and the buttons will not reset it as such (no dots under your buttons on this one 😉 ). However you need to press the 65 and eco 55 together, turn it on and shut the door. After a short while you should (just about) hear the timer clicking through the remainder of the cycle and switching off?
    It should now perform OK….hopefully? 😉
    #233486
    gixerk1
    thanks for clearing that up martin have tried the buttons still no joy
    do you think it may be a pump failure to to pumping into a blockage apparantly this has happened before but the water just comes into the sink im getting desparate now as the wife is waving a pair of marigolds at me
    tim
    #233487
    gegsy
    Martin wrote:There seems to be a bit of confusion over the programme buttons here? In fact your machine is NOT an electronic controlled machine
    Im sure I mentioned the hidden mechanical timer 😆
    A popular problem with these are broken wire/s in the bottom of the door where it hinges, power off before investigating. You could also check that the tiny motor on the time hasn’t gone west also 😉
    gixerk1
    apparantly water did overflow slightly thats why she switched it of
    and water did overflow i pressume into the hinge area
    tim
    #233489
    gixerk1 wrote:apparantly water did overflow slightly thats why she switched it of
    tim
    Do yourself a favour Tim and get expert help in to fix what is after all said and done a nice machine. Check the link below for a local engineer in your area. 😉
    #233490
    gixerk1
    thanks for everyones help i was thinking that myself
    i know when im beat will make an appointment monday
    thanks again
    tim
    #233491
    gixerk1
    hi guys
    pondered overnight the water in the bottom of the machine
    so today dragged it out a bit difficult due to it being intergrated
    unplugged and tipped it to the side with the least exposed wiring
    then mopped the floor and hit the button and of she went
    thanks again for your help
    tim
