neff s513K60X1G/06 tap light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries neff s513K60X1G/06 tap light
  • #102437
    mikehha
    could anyone tell me why the tap light comes on half way through a program and the dishwasher goes back to 00 no water in the bottom, good water pressure but I have noticed that the metering tank does not always fill. when the light comes on the pump does not keep running,when I say no water in the bottom the flood switch is not activated.apart from the reed switch that counts the water coming into the m/c is there another water level sensor
    #488834
    these days they use the pump motors as virtual sensors
    mikehha
    hi dave yes I can see they could measure the restiance to see if the motor is pushing water around but tha doesn`t explain why it stops and gose back to 00 and also why the metering tank stays empty.
    #488836
    does sound a bit like a software error
