Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › NEFF S513K60X1G not draining
- This topic has 6 replies, 2 voices, and was last updated 7 years, 10 months ago by
kenbamble.
June 20, 2018 at 8:46 am #94096
kenbamble
ParticipantGood morning.
We’ve had our fully integrated NEFF S513K60X1G for about two months, however yesterday we noticed it hadn’t pumped out the water from the last cycle. I checked the filter was clean, made sure the drain pipe wasn’t kinked or visibly blocked and tried to run it again. As soon as it starts up you hear a couple of clicks – presumably it trying to drain, then the machine beeps, and the screen displays an error code: E19.I’ve tried to Google the error code, but I can’t find any solid info about what it means. I was just wondering if anyone here had any insight, or suggestions on how I can fix it? It is still under warranty so we are eligible to get an engineer out, however if it’s something really simple I’d rather not have to wait for Neff to send someone.
Any help or suggestions would be gratefully received.
Thanks in advance.
June 20, 2018 at 7:42 pm #456446electrofix
ModeratorRe: NEFF S513K60X1G not draining
the pump on that machine can be accessed through the door. remove filter and there is a removable cover over the pump impellor. this will allow you to remove any blockage, normally glass
you instruction book normally had instruction on how to do it
June 21, 2018 at 10:05 am #456447kenbamble
ParticipantRe: NEFF S513K60X1G not draining
Hi Dave,
Thanks for getting back to me. I removed the filter and the cover over the impeller and had a feel about, but there is nothing blocking it – I was able to turn it without any difficulty. I also checked the manual but there doesn’t seem to be any entry for an E19 error.
Any idea what else it could be?
Thanks again
June 21, 2018 at 10:32 am #456448electrofix
Does the pump run when you try it? If it runs but still does not drain your looking at a blockage
June 21, 2018 at 11:08 am #456449kenbamble
Hi again. No it’s not pumping – every time I try and start a program and close the door, the machine clicks a couple of times, as if it’s trying to start something up, then it starts beeping and the display reads E19 😥
I also took the thin metal panel off the left-hand side and took a look there to see if there was anything obviously blocked or gunked up, but it’s pretty pristine. We’ve only had it a couple of months.
Do you have any other recommendations or suggestions?
Thanks again for your responses.
June 21, 2018 at 11:58 pm #456450electrofix
looking on Neff site E19 is fault in dispenser
https://www.neff-home.com/uk/supportdet … -firstaid/
June 22, 2018 at 7:42 am #456451kenbamble
Ah ha! Okay, I guess we’ll get a Neff engineer round about it then.
Thank you for all your responses. They were very helpful. :tup:
