Appears to work ok on quickwash,but stops on longer progams with a small amount of water left in base.If started again,continues to run for too long.
Fills,drains & washes ok when prompted.
The drain pump is noisy.Thinking replace pump or pcb fault?
Also the heat pumps are problematic on these.Wonder if this could be a cause?
No leaks evident.Machine is 5 years old.
