Neff S51E50X1GB/24
  • #94529
    Toni
    Does this dishwasher have the thermistor built in to the heat pump ?
    I cant find it anywhere on this one
    The heater is ok
    The module is ok, but still no heat
    Toni
    #457589
    Re: Neff S51E50X1GB/24
    there are 2 ntc mounted on the heater, small white plug next to heater connection
    nomadPaul
    Check the water level after approx 12 minutes. If it seems higher than usual, it may be the heat exchanger valve allowing water to overfill tank. If you can access the error codes , look for E08
